Time Before: 0.02085 seconds
Time After: 0.02657 seconds
Time Taken: 0.00573 seconds
Time Before: 0.02668 seconds
Time After: 0.02716 seconds
Time Before: 0.02745 seconds
Time After: 0.02763 seconds
Time Before: 0.02843 seconds
Time After: 0.03141 seconds
Time Taken: 0.00298 seconds
Time Before: 0.02772 seconds
Time After: 0.03563 seconds
Time Taken: 0.00792 seconds
Time Before: 0.04428 seconds
Time After: 0.04466 seconds
Time Before: 0.04601 seconds
Time After: 0.04727 seconds
Time Before: 0.04365 seconds
Time After: 0.04748 seconds
Time Taken: 0.00383 seconds
Time Before: 0.09092 seconds
Time After: 0.09109 seconds
Time Before: 0.11372 seconds
Time After: 0.11496 seconds
Time Before: 0.12526 seconds
Time After: 0.12543 seconds
Time Before: 0.12822 seconds
Time After: 0.12966 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=81726', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.14607 seconds
Time After: 0.14635 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
