Time Before: 0.00314 seconds
Time After: 0.00406 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00415 seconds
Time After: 0.00468 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00496 seconds
Time After: 0.00511 seconds
Time Before: 0.00599 seconds
Time After: 0.00832 seconds
Time Taken: 0.00233 seconds
Time Before: 0.00518 seconds
Time After: 0.01383 seconds
Time Taken: 0.00865 seconds
Time Before: 0.01638 seconds
Time After: 0.01691 seconds
Time Before: 0.01953 seconds
Time After: 0.02075 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.01555 seconds
Time After: 0.02102 seconds
Time Taken: 0.00547 seconds
Memory After: 2,261.719 KB
Time Before: 0.02940 seconds
Time After: 0.03023 seconds
Time Taken: 0.00083 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.03308 seconds
Time After: 0.03434 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.036874055862427
Time Before: 0.03836 seconds
Time After: 0.03855 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.04128 seconds
Time After: 0.04300 seconds
Time Taken: 0.00172 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=81784', badlocation = 1
Time Before: 0.06230 seconds
Time After: 0.06263 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.061187982559204 seconds with 9 queries, spending 0.0091075897216797 doing MySQL queries and 0.052080392837524 doing PHP things.
