Time Before: 0.00158 seconds
Time After: 0.00227 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00236 seconds
Time After: 0.00271 seconds
Time Before: 0.00289 seconds
Time After: 0.00303 seconds
Time Before: 0.00370 seconds
Time After: 0.00658 seconds
Time Taken: 0.00288 seconds
Time Before: 0.00308 seconds
Time After: 0.00993 seconds
Time Taken: 0.00686 seconds
Time Before: 0.01188 seconds
Time After: 0.01229 seconds
Time Before: 0.01362 seconds
Time After: 0.01491 seconds
Time Before: 0.01122 seconds
Time After: 0.01509 seconds
Time Taken: 0.00387 seconds
Time Before: 0.02038 seconds
Time After: 0.02050 seconds
Time Before: 0.02246 seconds
Time After: 0.02376 seconds
End call of global.php: 0.025738954544067
Time Before: 0.02693 seconds
Time After: 0.02712 seconds
Time Before: 0.02907 seconds
Time After: 0.03052 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=81835'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04311 seconds
Time After: 0.04346 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
Page generated in 0.042196989059448 seconds with 9 queries, spending 0.0084743499755859 doing MySQL queries and 0.033722639083862 doing PHP things.
