Time Before: 0.01888 seconds
Time After: 0.02330 seconds
Time Taken: 0.00441 seconds
Time Before: 0.02338 seconds
Time After: 0.02384 seconds
Time Before: 0.02406 seconds
Time After: 0.02426 seconds
Time Before: 0.02513 seconds
Time After: 0.02701 seconds
Time Taken: 0.00188 seconds
Time Before: 0.02431 seconds
Time After: 0.03222 seconds
Time Taken: 0.00791 seconds
Time Before: 0.04138 seconds
Time After: 0.04184 seconds
Time Before: 0.04356 seconds
Time After: 0.04478 seconds
Time Before: 0.04058 seconds
Time After: 0.04501 seconds
Time Taken: 0.00444 seconds
Time Before: 0.09349 seconds
Time After: 0.09362 seconds
Time Before: 0.11180 seconds
Time After: 0.11309 seconds
End call of global.php: 0.11588096618652
Time Before: 0.12872 seconds
Time After: 0.12889 seconds
Time Before: 0.13152 seconds
Time After: 0.13296 seconds
SET lastactivity = 1785399922, location = '/forums/private.php?do=newpm&explain=1&u=81860'
Time Before: 0.15361 seconds
Time After: 0.15398 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.15251111984253 seconds with 9 queries, spending 0.0076055526733398 doing MySQL queries and 0.14490556716919 doing PHP things.
