Time Before: 0.00198 seconds
Time After: 0.00256 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00266 seconds
Time After: 0.00311 seconds
Time Before: 0.00332 seconds
Time After: 0.00343 seconds
Time Before: 0.00418 seconds
Time After: 0.00661 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00347 seconds
Time After: 0.01003 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01217 seconds
Time After: 0.01263 seconds
Time Before: 0.01569 seconds
Time After: 0.01697 seconds
Time Before: 0.01146 seconds
Time After: 0.01714 seconds
Time Taken: 0.00568 seconds
Time Before: 0.02300 seconds
Time After: 0.02311 seconds
Time Before: 0.02576 seconds
Time After: 0.02701 seconds
End call of global.php: 0.028738021850586
Time Before: 0.03048 seconds
Time After: 0.03063 seconds
Time Before: 0.03313 seconds
Time After: 0.03456 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=81952', badlocation = 1
Time Before: 0.04704 seconds
Time After: 0.04733 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.046129941940308 seconds with 9 queries, spending 0.0079550743103027 doing MySQL queries and 0.038174867630005 doing PHP things.
