Time Before: 0.01160 seconds
Time After: 0.02169 seconds
Time Taken: 0.01009 seconds
Time Before: 0.02179 seconds
Time After: 0.02222 seconds
Time Before: 0.02247 seconds
Time After: 0.02262 seconds
Time Before: 0.02336 seconds
Time After: 0.02533 seconds
Time Taken: 0.00198 seconds
Time Before: 0.02267 seconds
Time After: 0.02911 seconds
Time Taken: 0.00644 seconds
Time Before: 0.03754 seconds
Time After: 0.03790 seconds
Time Before: 0.04071 seconds
Time After: 0.04239 seconds
Time Taken: 0.00168 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03684 seconds
Time After: 0.04257 seconds
Time Taken: 0.00573 seconds
Memory After: 2,261.719 KB
Time Before: 0.06204 seconds
Time After: 0.06256 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.08282 seconds
Time After: 0.08408 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.086359977722168
Time Before: 0.09385 seconds
Time After: 0.09417 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.09688 seconds
Time After: 0.09831 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=82026', badlocation = 1
Time Before: 0.11833 seconds
Time After: 0.11865 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.11739587783813 seconds with 9 queries, spending 0.0084335803985596 doing MySQL queries and 0.10896229743958 doing PHP things.
