Time Before: 0.00655 seconds
Time After: 0.00813 seconds
Time Taken: 0.00157 seconds
Time Before: 0.00823 seconds
Time After: 0.00944 seconds
Time Before: 0.00978 seconds
Time After: 0.00992 seconds
Time Before: 0.01056 seconds
Time After: 0.01444 seconds
Time Taken: 0.00388 seconds
Time Before: 0.00998 seconds
Time After: 0.01847 seconds
Time Taken: 0.00849 seconds
Time Before: 0.02266 seconds
Time After: 0.02303 seconds
Time Before: 0.02517 seconds
Time After: 0.02670 seconds
Time Taken: 0.00153 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02181 seconds
Time After: 0.02691 seconds
Time Taken: 0.00510 seconds
Memory After: 2,261.836 KB
Time Before: 0.03929 seconds
Time After: 0.03945 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04683 seconds
Time After: 0.04810 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.049743890762329
Time Before: 0.05220 seconds
Time After: 0.05236 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.05422 seconds
Time After: 0.05575 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788879238, location = '/forums/private.php?do=newpm&explain=1&u=82070'
Time Before: 0.06843 seconds
Time After: 0.06894 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 0.067526817321777 seconds with 9 queries, spending 0.010769367218018 doing MySQL queries and 0.05675745010376 doing PHP things.
