Time Before: 0.00213 seconds
Time After: 0.00261 seconds
Time Before: 0.00269 seconds
Time After: 0.00340 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00370 seconds
Time After: 0.00387 seconds
Time Before: 0.00459 seconds
Time After: 0.00754 seconds
Time Taken: 0.00295 seconds
Time Before: 0.00392 seconds
Time After: 0.01096 seconds
Time Taken: 0.00704 seconds
Time Before: 0.01267 seconds
Time After: 0.01303 seconds
Time Before: 0.01547 seconds
Time After: 0.01677 seconds
Time Before: 0.01209 seconds
Time After: 0.01695 seconds
Time Taken: 0.00486 seconds
Time Before: 0.02173 seconds
Time After: 0.02189 seconds
Time Before: 0.02394 seconds
Time After: 0.02524 seconds
Time Before: 0.02812 seconds
Time After: 0.02829 seconds
Time Before: 0.03026 seconds
Time After: 0.03170 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=82087', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04461 seconds
Time After: 0.04493 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
