Time Before: 0.00739 seconds
Time After: 0.00933 seconds
Time Taken: 0.00194 seconds
Time Before: 0.00941 seconds
Time After: 0.00984 seconds
Time Before: 0.01006 seconds
Time After: 0.01021 seconds
Time Before: 0.01133 seconds
Time After: 0.01475 seconds
Time Taken: 0.00343 seconds
Time Before: 0.01027 seconds
Time After: 0.01922 seconds
Time Taken: 0.00895 seconds
Time Before: 0.02310 seconds
Time After: 0.02334 seconds
Time Before: 0.02607 seconds
Time After: 0.02731 seconds
Time Before: 0.02240 seconds
Time After: 0.02753 seconds
Time Taken: 0.00512 seconds
Time Before: 0.04520 seconds
Time After: 0.04537 seconds
Time Before: 0.23936 seconds
Time After: 0.24064 seconds
Time Before: 0.24967 seconds
Time After: 0.24990 seconds
Time Before: 0.25235 seconds
Time After: 0.25387 seconds
Time Taken: 0.00152 seconds
UPDATE session SET lastactivity = 1783390423, location = '/forums/private.php?do=newpm&explain=1&u=82118', badlocation = 1 WHERE sessionhash = '32502f71822f8bf82bf8c86767d671b1'
Time Before: 0.27093 seconds
Time After: 0.27120 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
