Time Before: 0.00214 seconds
Time After: 0.00287 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00294 seconds
Time After: 0.00342 seconds
Time Before: 0.00364 seconds
Time After: 0.00380 seconds
Time Before: 0.00442 seconds
Time After: 0.00735 seconds
Time Taken: 0.00293 seconds
Time Before: 0.00384 seconds
Time After: 0.01072 seconds
Time Taken: 0.00688 seconds
Time Before: 0.01258 seconds
Time After: 0.01294 seconds
Time Before: 0.01424 seconds
Time After: 0.01546 seconds
Time Before: 0.01194 seconds
Time After: 0.01563 seconds
Time Taken: 0.00369 seconds
Time Before: 0.02039 seconds
Time After: 0.02051 seconds
Time Before: 0.02247 seconds
Time After: 0.02369 seconds
Time Before: 0.02735 seconds
Time After: 0.02752 seconds
Time Before: 0.02998 seconds
Time After: 0.03144 seconds
UPDATE session SET lastactivity = 1789136984, location = '/forums/private.php?do=newpm&explain=1&u=82250' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04620 seconds
Time After: 0.04660 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
