Time Before: 0.03150 seconds
Time After: 0.04057 seconds
Time Taken: 0.00907 seconds
Time Before: 0.04065 seconds
Time After: 0.04122 seconds
Time Taken: 0.00057 seconds
Time Before: 0.04153 seconds
Time After: 0.04174 seconds
Time Before: 0.04249 seconds
Time After: 0.04518 seconds
Time Taken: 0.00269 seconds
Time Before: 0.04180 seconds
Time After: 0.04931 seconds
Time Taken: 0.00752 seconds
Time Before: 0.06349 seconds
Time After: 0.06390 seconds
Time Before: 0.06631 seconds
Time After: 0.06753 seconds
Time Before: 0.06274 seconds
Time After: 0.06775 seconds
Time Taken: 0.00501 seconds
Time Before: 0.11054 seconds
Time After: 0.11070 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"43.28,\";s:9:\"lastcheck\";i:1782931715;}', 1)Time Before: 0.12800 seconds
Time After: 0.12863 seconds
Time Taken: 0.00064 seconds
Memory Before: 3,439.641 KB
Memory After: 3,439.891 KB
Memory Used: 0.250 KB
Time Before: 0.15512 seconds
Time After: 0.15641 seconds
Memory Before: 3,526.445 KB
Memory After: 3,527.039 KB
Time Before: 0.16446 seconds
Time After: 0.16492 seconds
Memory Before: 4,164.313 KB
Memory After: 4,164.742 KB
Time Before: 0.16728 seconds
Time After: 0.16876 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1782931715, location = '/forums/private.php?do=newpm&explain=1&u=8227' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.18796 seconds
Time After: 0.18829 seconds
Memory Before: 4,919.734 KB
Memory After: 4,919.938 KB
Memory Used: 0.203 KB
