Time Before: 0.01177 seconds
Time After: 0.01683 seconds
Time Taken: 0.00506 seconds
Time Before: 0.01693 seconds
Time After: 0.01747 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01767 seconds
Time After: 0.01778 seconds
Time Before: 0.01859 seconds
Time After: 0.02072 seconds
Time Taken: 0.00214 seconds
Time Before: 0.01783 seconds
Time After: 0.02497 seconds
Time Taken: 0.00714 seconds
Time Before: 0.02993 seconds
Time After: 0.03034 seconds
Time Before: 0.03320 seconds
Time After: 0.03438 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02914 seconds
Time After: 0.03461 seconds
Time Taken: 0.00547 seconds
Memory After: 2,261.719 KB
Time Before: 0.05625 seconds
Time After: 0.05638 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06907 seconds
Time After: 0.07031 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.073325872421265
Time Before: 0.07932 seconds
Time After: 0.07957 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.08209 seconds
Time After: 0.08352 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=82273'
Time Before: 0.10250 seconds
Time After: 0.10275 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.10133910179138 seconds with 9 queries, spending 0.0076830387115479 doing MySQL queries and 0.093656063079834 doing PHP things.
