Time Before: 0.01959 seconds
Time After: 0.02515 seconds
Time Taken: 0.00555 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.02523 seconds
Time After: 0.02567 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.02589 seconds
Time After: 0.02607 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02684 seconds
Time After: 0.02955 seconds
Time Taken: 0.00272 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02613 seconds
Time After: 0.03352 seconds
Time Taken: 0.00739 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03987 seconds
Time After: 0.04034 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04315 seconds
Time After: 0.04440 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.03922 seconds
Time After: 0.04460 seconds
Time Taken: 0.00538 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.07727 seconds
Time After: 0.07741 seconds
Memory Before: 3,655.734 KB
Memory After: 3,656.250 KB
Time Before: 0.11698 seconds
Time After: 0.11824 seconds
Memory Before: 4,133.250 KB
Memory After: 4,133.844 KB
End call of global.php: 0.12050199508667
Time Before: 0.13947 seconds
Time After: 0.13963 seconds
Memory Before: 5,197.492 KB
Memory After: 5,325.836 KB
Time Before: 0.14315 seconds
Time After: 0.14462 seconds
Memory Before: 5,481.172 KB
Memory After: 5,610.773 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=82346'
WHERE sessionhash = '84a1ba763b341c65c6e779f4d27b10fd'
Time Before: 0.16799 seconds
Time After: 0.16831 seconds
Memory Before: 5,998.203 KB
Memory After: 5,998.445 KB
Page generated in 0.16686987876892 seconds with 9 queries, spending 0.0083928108215332 doing MySQL queries and 0.15847706794739 doing PHP things.
