Time Before: 0.00156 seconds
Time After: 0.00200 seconds
Time Before: 0.00207 seconds
Time After: 0.00262 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00286 seconds
Time After: 0.00298 seconds
Time Before: 0.00364 seconds
Time After: 0.00627 seconds
Time Taken: 0.00263 seconds
Time Before: 0.00303 seconds
Time After: 0.00968 seconds
Time Taken: 0.00665 seconds
Time Before: 0.01149 seconds
Time After: 0.01189 seconds
Time Before: 0.01449 seconds
Time After: 0.01583 seconds
Time Taken: 0.00134 seconds
Time Before: 0.01084 seconds
Time After: 0.01601 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02257 seconds
Time After: 0.02279 seconds
Time Before: 0.02481 seconds
Time After: 0.02608 seconds
End call of global.php: 0.027843952178955
Time Before: 0.02923 seconds
Time After: 0.02939 seconds
Time Before: 0.03150 seconds
Time After: 0.03294 seconds
SET lastactivity = 1772774652, location = '/forums/private.php?do=newpm&explain=1&u=82384', badlocation = 1
WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.04532 seconds
Time After: 0.04572 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.044417142868042 seconds with 9 queries, spending 0.00852370262146 doing MySQL queries and 0.035893440246582 doing PHP things.
