Time Before: 0.01557 seconds
Time After: 0.02038 seconds
Time Taken: 0.00480 seconds
Time Before: 0.02047 seconds
Time After: 0.02090 seconds
Time Before: 0.02115 seconds
Time After: 0.02131 seconds
Time Before: 0.02309 seconds
Time After: 0.02742 seconds
Time Taken: 0.00433 seconds
Time Before: 0.02142 seconds
Time After: 0.03246 seconds
Time Taken: 0.01105 seconds
Time Before: 0.03966 seconds
Time After: 0.04009 seconds
Time Before: 0.04273 seconds
Time After: 0.04439 seconds
Time Taken: 0.00167 seconds
Time Before: 0.03899 seconds
Time After: 0.04466 seconds
Time Taken: 0.00567 seconds
Time Before: 0.06350 seconds
Time After: 0.06367 seconds
Time Before: 0.08329 seconds
Time After: 0.08462 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.087280988693237
Time Before: 0.09363 seconds
Time After: 0.09380 seconds
Time Before: 0.09702 seconds
Time After: 0.09949 seconds
Time Taken: 0.00247 seconds
SET lastactivity = 1789128147, location = '/forums/private.php?do=newpm&explain=1&u=82399'
Time Before: 0.12048 seconds
Time After: 0.12090 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.11941003799438 seconds with 9 queries, spending 0.011584043502808 doing MySQL queries and 0.10782599449158 doing PHP things.
