Time Before: 0.01582 seconds
Time After: 0.01995 seconds
Time Taken: 0.00413 seconds
Time Before: 0.02006 seconds
Time After: 0.02052 seconds
Time Before: 0.02075 seconds
Time After: 0.02091 seconds
Time Before: 0.02177 seconds
Time After: 0.02420 seconds
Time Taken: 0.00243 seconds
Time Before: 0.02098 seconds
Time After: 0.02843 seconds
Time Taken: 0.00745 seconds
Time Before: 0.03409 seconds
Time After: 0.03450 seconds
Time Before: 0.03612 seconds
Time After: 0.03732 seconds
Time Before: 0.03332 seconds
Time After: 0.03757 seconds
Time Taken: 0.00425 seconds
Time Before: 0.07066 seconds
Time After: 0.07082 seconds
Time Before: 0.08473 seconds
Time After: 0.08596 seconds
End call of global.php: 0.087832927703857
Time Before: 0.09313 seconds
Time After: 0.09329 seconds
Time Before: 0.09538 seconds
Time After: 0.09680 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=82421'
Time Before: 0.11264 seconds
Time After: 0.11708 seconds
Time Taken: 0.00444 seconds
Memory Before: 4,911.656 KB
Memory After: 4,911.898 KB
Page generated in 0.11172986030579 seconds with 9 queries, spending 0.012040615081787 doing MySQL queries and 0.099689245223999 doing PHP things.
