Time Before: 0.00170 seconds
Time After: 0.00229 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00238 seconds
Time After: 0.00282 seconds
Time Before: 0.00303 seconds
Time After: 0.00323 seconds
Time Before: 0.00400 seconds
Time After: 0.00645 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00330 seconds
Time After: 0.01028 seconds
Time Taken: 0.00698 seconds
Time Before: 0.01262 seconds
Time After: 0.01301 seconds
Time Before: 0.01446 seconds
Time After: 0.01560 seconds
Time Taken: 0.00114 seconds
Time Before: 0.01192 seconds
Time After: 0.01577 seconds
Time Taken: 0.00385 seconds
Time Before: 0.02226 seconds
Time After: 0.02242 seconds
Time Before: 0.02468 seconds
Time After: 0.02590 seconds
Time Before: 0.02873 seconds
Time After: 0.02890 seconds
Time Before: 0.03092 seconds
Time After: 0.03235 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=82486', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04775 seconds
Time After: 0.04802 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
