Time Before: 0.00134 seconds
Time After: 0.00190 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00197 seconds
Time After: 0.00253 seconds
Time Before: 0.00280 seconds
Time After: 0.00298 seconds
Time Before: 0.00382 seconds
Time After: 0.00632 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00306 seconds
Time After: 0.01045 seconds
Time Taken: 0.00740 seconds
Time Before: 0.01236 seconds
Time After: 0.01261 seconds
Time Before: 0.01569 seconds
Time After: 0.01694 seconds
Time Before: 0.01163 seconds
Time After: 0.01718 seconds
Time Taken: 0.00555 seconds
Time Before: 0.02436 seconds
Time After: 0.02450 seconds
Time Before: 0.02681 seconds
Time After: 0.02810 seconds
Time Before: 0.03241 seconds
Time After: 0.03255 seconds
Time Before: 0.03478 seconds
Time After: 0.03619 seconds
UPDATE session SET lastactivity = 1783019167, location = '/forums/private.php?do=newpm&explain=1&u=82492' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.05236 seconds
Time After: 0.05271 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
