Time Before: 0.00137 seconds
Time After: 0.00186 seconds
Time Before: 0.00193 seconds
Time After: 0.00235 seconds
Time Before: 0.00263 seconds
Time After: 0.00277 seconds
Time Before: 0.00341 seconds
Time After: 0.00594 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00282 seconds
Time After: 0.00929 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01113 seconds
Time After: 0.01155 seconds
Time Before: 0.01395 seconds
Time After: 0.01515 seconds
Time Before: 0.01057 seconds
Time After: 0.01532 seconds
Time Taken: 0.00474 seconds
Time Before: 0.02009 seconds
Time After: 0.02024 seconds
Time Before: 0.02205 seconds
Time After: 0.02328 seconds
Time Before: 0.02640 seconds
Time After: 0.02660 seconds
Time Before: 0.02859 seconds
Time After: 0.03004 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=82497' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.04347 seconds
Time After: 0.04375 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
