Time Before: 0.02167 seconds
Time After: 0.02662 seconds
Time Taken: 0.00495 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02676 seconds
Time After: 0.02723 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.02747 seconds
Time After: 0.02760 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.02841 seconds
Time After: 0.03077 seconds
Time Taken: 0.00236 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.02765 seconds
Time After: 0.03508 seconds
Time Taken: 0.00743 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.03838 seconds
Time After: 0.03886 seconds
Time Before: 0.04049 seconds
Time After: 0.04200 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03777 seconds
Time After: 0.04220 seconds
Time Taken: 0.00443 seconds
Memory After: 2,261.703 KB
Time Before: 0.08290 seconds
Time After: 0.08307 seconds
Memory Before: 2,815.273 KB
Memory After: 2,815.789 KB
Time Before: 0.09804 seconds
Time After: 0.09930 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.10860 seconds
Time After: 0.10875 seconds
Memory Before: 3,540.375 KB
Memory After: 3,540.805 KB
Time Before: 0.11100 seconds
Time After: 0.11243 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=82520' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.13271 seconds
Time After: 0.13302 seconds
Memory Before: 4,295.484 KB
Memory After: 4,295.727 KB
