Time Before: 0.00233 seconds
Time After: 0.00299 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00310 seconds
Time After: 0.00367 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00389 seconds
Time After: 0.00406 seconds
Time Before: 0.00478 seconds
Time After: 0.00708 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00411 seconds
Time After: 0.01050 seconds
Time Taken: 0.00639 seconds
Time Before: 0.01223 seconds
Time After: 0.01261 seconds
Time Before: 0.01521 seconds
Time After: 0.01639 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01168 seconds
Time After: 0.01658 seconds
Time Taken: 0.00490 seconds
Time Before: 0.02224 seconds
Time After: 0.02236 seconds
Time Before: 0.02458 seconds
Time After: 0.02585 seconds
End call of global.php: 0.027467012405396
Time Before: 0.02887 seconds
Time After: 0.02899 seconds
Time Before: 0.03096 seconds
Time After: 0.03248 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=82531', badlocation = 1
Time Before: 0.04474 seconds
Time After: 0.04498 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.043843984603882 seconds with 9 queries, spending 0.0078647136688232 doing MySQL queries and 0.035979270935059 doing PHP things.
