Time Before: 0.00156 seconds
Time After: 0.00218 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00225 seconds
Time After: 0.00268 seconds
Time Before: 0.00292 seconds
Time After: 0.00304 seconds
Time Before: 0.00380 seconds
Time After: 0.00649 seconds
Time Taken: 0.00269 seconds
Time Before: 0.00308 seconds
Time After: 0.01090 seconds
Time Taken: 0.00782 seconds
Time Before: 0.01309 seconds
Time After: 0.01348 seconds
Time Before: 0.01602 seconds
Time After: 0.01726 seconds
Time Before: 0.01238 seconds
Time After: 0.01752 seconds
Time Taken: 0.00515 seconds
Time Before: 0.02309 seconds
Time After: 0.02326 seconds
Time Before: 0.02565 seconds
Time After: 0.02691 seconds
End call of global.php: 0.029416084289551
Time Before: 0.03085 seconds
Time After: 0.03100 seconds
Time Before: 0.03292 seconds
Time After: 0.03448 seconds
Time Taken: 0.00156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=82566', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.04778 seconds
Time After: 0.04804 seconds
Memory Before: 4,288.836 KB
Memory After: 4,289.063 KB
Page generated in 0.046571969985962 seconds with 9 queries, spending 0.0082714557647705 doing MySQL queries and 0.038300514221191 doing PHP things.
