Time Before: 0.00144 seconds
Time After: 0.00188 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00194 seconds
Time After: 0.00255 seconds
Time Taken: 0.00061 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00281 seconds
Time After: 0.00292 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00362 seconds
Time After: 0.00609 seconds
Time Taken: 0.00247 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00297 seconds
Time After: 0.00950 seconds
Time Taken: 0.00654 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01173 seconds
Time After: 0.01215 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.01574 seconds
Time After: 0.01697 seconds
Memory Before: 2,771.523 KB
Memory After: 2,771.383 KB
Time Before: 0.01096 seconds
Time After: 0.01722 seconds
Time Taken: 0.00626 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.414 KB
Time Before: 0.02251 seconds
Time After: 0.02274 seconds
Memory Before: 3,437.547 KB
Memory After: 3,438.063 KB
Time Before: 0.02472 seconds
Time After: 0.02595 seconds
Memory Before: 3,525.344 KB
Memory After: 3,525.938 KB
End call of global.php: 0.027657985687256
Time Before: 0.02906 seconds
Time After: 0.02927 seconds
Memory Before: 4,163.203 KB
Memory After: 4,163.633 KB
Time Before: 0.03139 seconds
Time After: 0.03285 seconds
Memory Before: 4,444.766 KB
Memory After: 4,446.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=82601'
Time Before: 0.04572 seconds
Time After: 0.04615 seconds
Memory Before: 4,918.352 KB
Memory After: 4,918.594 KB
Page generated in 0.044821977615356 seconds with 9 queries, spending 0.0084028244018555 doing MySQL queries and 0.036419153213501 doing PHP things.
