Time Before: 0.00152 seconds
Time After: 0.00199 seconds
Time Before: 0.00205 seconds
Time After: 0.00265 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00288 seconds
Time After: 0.00299 seconds
Time Before: 0.00362 seconds
Time After: 0.00629 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00304 seconds
Time After: 0.00973 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01144 seconds
Time After: 0.01165 seconds
Time Before: 0.01350 seconds
Time After: 0.01470 seconds
Time Before: 0.01091 seconds
Time After: 0.01488 seconds
Time Taken: 0.00397 seconds
Time Before: 0.02022 seconds
Time After: 0.02036 seconds
Time Before: 0.85741 seconds
Time After: 0.85976 seconds
Time Taken: 0.00235 seconds
End call of global.php: 0.86292290687561
Time Before: 0.86483 seconds
Time After: 0.86497 seconds
Time Before: 0.86782 seconds
Time After: 0.86992 seconds
Time Taken: 0.00211 seconds
SET lastactivity = 1789019747, location = '/forums/private.php?do=newpm&explain=1&u=82621', badlocation = 1
Time Before: 0.88256 seconds
Time After: 0.88276 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.88165593147278 seconds with 9 queries, spending 0.0097017288208008 doing MySQL queries and 0.87195420265198 doing PHP things.
