Time Before: 0.01591 seconds
Time After: 0.02647 seconds
Time Taken: 0.01056 seconds
Memory Before: 532.906 KB
Memory After: 558.023 KB
Time Before: 0.02658 seconds
Time After: 0.02725 seconds
Time Taken: 0.00066 seconds
Memory Before: 557.961 KB
Memory After: 558.969 KB
Time Before: 0.02754 seconds
Time After: 0.02769 seconds
Memory Before: 559.523 KB
Memory After: 560.047 KB
Time Before: 0.02846 seconds
Time After: 0.03106 seconds
Time Taken: 0.00260 seconds
Memory Before: 562.648 KB
Memory After: 563.570 KB
Time Before: 0.02776 seconds
Time After: 0.03511 seconds
Time Taken: 0.00734 seconds
Memory Before: 559.297 KB
Memory After: 1,640.391 KB
Memory Used: 1,081.094 KB
Time Before: 0.04521 seconds
Time After: 0.04557 seconds
Memory Before: 2,135.344 KB
Memory After: 2,135.961 KB
Time Before: 0.04813 seconds
Time After: 0.04934 seconds
Memory Before: 2,147.523 KB
Memory After: 2,147.383 KB
Time Before: 0.04456 seconds
Time After: 0.04959 seconds
Time Taken: 0.00503 seconds
Memory Before: 2,127.523 KB
Memory After: 2,260.734 KB
Memory Used: 133.211 KB
Time Before: 0.07476 seconds
Time After: 0.07491 seconds
Memory Before: 2,814.250 KB
Memory After: 2,814.766 KB
Time Before: 0.09439 seconds
Time After: 0.09561 seconds
Memory Before: 2,902.586 KB
Memory After: 2,903.180 KB
Time Before: 0.10523 seconds
Time After: 0.10537 seconds
Memory Before: 3,539.344 KB
Memory After: 3,539.773 KB
Time Before: 0.10805 seconds
Time After: 0.10950 seconds
Memory Before: 3,821.078 KB
Memory After: 3,822.766 KB
UPDATE session SET lastactivity = 1776853231, location = '/forums/private.php?do=newpm&explain=1&u=82685', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.12865 seconds
Time After: 0.12912 seconds
Memory Before: 4,299.531 KB
Memory After: 4,299.742 KB
