Time Before: 0.00190 seconds
Time After: 0.00255 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00265 seconds
Time After: 0.00311 seconds
Time Before: 0.00339 seconds
Time After: 0.00359 seconds
Time Before: 0.00449 seconds
Time After: 0.00696 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00366 seconds
Time After: 0.01234 seconds
Time Taken: 0.00868 seconds
Time Before: 0.01431 seconds
Time After: 0.01473 seconds
Time Before: 0.01614 seconds
Time After: 0.01739 seconds
Time Before: 0.01363 seconds
Time After: 0.01765 seconds
Time Taken: 0.00402 seconds
Time Before: 0.02521 seconds
Time After: 0.02543 seconds
Time Before: 0.02804 seconds
Time After: 0.02936 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.032188892364502
Time Before: 0.03365 seconds
Time After: 0.03378 seconds
Time Before: 0.03600 seconds
Time After: 0.03744 seconds
SET lastactivity = 1773029858, location = '/forums/private.php?do=newpm&explain=1&u=82752'
WHERE sessionhash = '90748b3bc0ca0216971875da8c52c58c'
Time Before: 0.05017 seconds
Time After: 0.05049 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049248933792114 seconds with 9 queries, spending 0.0082201957702637 doing MySQL queries and 0.041028738021851 doing PHP things.
