Time Before: 0.00156 seconds
Time After: 0.00211 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00217 seconds
Time After: 0.00252 seconds
Time Before: 0.00269 seconds
Time After: 0.00290 seconds
Time Before: 0.00359 seconds
Time After: 0.00560 seconds
Time Taken: 0.00201 seconds
Time Before: 0.00295 seconds
Time After: 0.00893 seconds
Time Taken: 0.00598 seconds
Time Before: 0.01082 seconds
Time After: 0.01136 seconds
Time Before: 0.01400 seconds
Time After: 0.01515 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01017 seconds
Time After: 0.01534 seconds
Time Taken: 0.00517 seconds
Time Before: 0.02049 seconds
Time After: 0.02075 seconds
Time Before: 0.02272 seconds
Time After: 0.02398 seconds
End call of global.php: 0.025753021240234
Time Before: 0.02696 seconds
Time After: 0.02712 seconds
Time Before: 0.02913 seconds
Time After: 0.03059 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=82810'
Time Before: 0.04881 seconds
Time After: 0.04919 seconds
Memory Before: 4,288.555 KB
Memory After: 4,288.797 KB
Page generated in 0.047523021697998 seconds with 9 queries, spending 0.0077810287475586 doing MySQL queries and 0.039741992950439 doing PHP things.
