Time Before: 0.00193 seconds
Time After: 0.00250 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00256 seconds
Time After: 0.00314 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00337 seconds
Time After: 0.00347 seconds
Time Before: 0.00420 seconds
Time After: 0.00693 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00352 seconds
Time After: 0.01038 seconds
Time Taken: 0.00685 seconds
Time Before: 0.01233 seconds
Time After: 0.01269 seconds
Time Before: 0.01503 seconds
Time After: 0.01618 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01167 seconds
Time After: 0.01635 seconds
Time Taken: 0.00468 seconds
Time Before: 0.02146 seconds
Time After: 0.02165 seconds
Time Before: 0.02348 seconds
Time After: 0.02468 seconds
End call of global.php: 0.026297092437744
Time Before: 0.02750 seconds
Time After: 0.02766 seconds
Time Before: 0.02955 seconds
Time After: 0.03099 seconds
SET lastactivity = 1784887494, location = '/forums/private.php?do=newpm&explain=1&u=82905', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04348 seconds
Time After: 0.04384 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.042546033859253 seconds with 9 queries, spending 0.0082759857177734 doing MySQL queries and 0.034270048141479 doing PHP things.
