Time Before: 0.02394 seconds
Time After: 0.03172 seconds
Time Taken: 0.00778 seconds
Time Before: 0.03182 seconds
Time After: 0.03225 seconds
Time Before: 0.03251 seconds
Time After: 0.03263 seconds
Time Before: 0.03351 seconds
Time After: 0.03555 seconds
Time Taken: 0.00204 seconds
Time Before: 0.03268 seconds
Time After: 0.03945 seconds
Time Taken: 0.00676 seconds
Time Before: 0.04954 seconds
Time After: 0.04974 seconds
Time Before: 0.05139 seconds
Time After: 0.05256 seconds
Time Taken: 0.00117 seconds
Time Before: 0.04879 seconds
Time After: 0.05276 seconds
Time Taken: 0.00397 seconds
Time Before: 0.08793 seconds
Time After: 0.08812 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"30.33,\";s:9:\"lastcheck\";i:1783090261;}', 1)Time Before: 0.10557 seconds
Time After: 0.10588 seconds
Memory Before: 2,817.273 KB
Memory After: 2,817.523 KB
Memory Used: 0.250 KB
Time Before: 0.68535 seconds
Time After: 0.68708 seconds
Time Taken: 0.00173 seconds
Memory Before: 2,904.578 KB
Memory After: 2,905.172 KB
Time Before: 0.69901 seconds
Time After: 0.69917 seconds
Memory Before: 3,541.367 KB
Memory After: 3,541.797 KB
Time Before: 0.70216 seconds
Time After: 0.70360 seconds
Memory Before: 3,823.109 KB
Memory After: 3,824.797 KB
UPDATE session SET lastactivity = 1783090261, location = '/forums/private.php?do=newpm&explain=1&u=83053', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.72137 seconds
Time After: 0.72165 seconds
Memory Before: 4,297.883 KB
Memory After: 4,298.070 KB
Memory Used: 0.188 KB
