Time Before: 0.02740 seconds
Time After: 0.03277 seconds
Time Taken: 0.00537 seconds
Time Before: 0.03287 seconds
Time After: 0.03327 seconds
Time Before: 0.03349 seconds
Time After: 0.03364 seconds
Time Before: 0.03453 seconds
Time After: 0.03715 seconds
Time Taken: 0.00261 seconds
Time Before: 0.03370 seconds
Time After: 0.04172 seconds
Time Taken: 0.00802 seconds
Time Before: 0.05124 seconds
Time After: 0.05164 seconds
Time Before: 0.05501 seconds
Time After: 0.05634 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05040 seconds
Time After: 0.05662 seconds
Time Taken: 0.00623 seconds
Memory After: 2,261.719 KB
Time Before: 0.10269 seconds
Time After: 0.10282 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.49176 seconds
Time After: 0.49424 seconds
Time Taken: 0.00249 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.50509 seconds
Time After: 0.50524 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.50776 seconds
Time After: 0.50936 seconds
Time Taken: 0.00160 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=83213', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.52807 seconds
Time After: 0.52839 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
