Time Before: 0.01423 seconds
Time After: 0.02232 seconds
Time Taken: 0.00809 seconds
Time Before: 0.02243 seconds
Time After: 0.02284 seconds
Time Before: 0.02309 seconds
Time After: 0.02326 seconds
Time Before: 0.02412 seconds
Time After: 0.02630 seconds
Time Taken: 0.00218 seconds
Time Before: 0.02334 seconds
Time After: 0.03057 seconds
Time Taken: 0.00722 seconds
Time Before: 0.03604 seconds
Time After: 0.03645 seconds
Time Before: 0.03969 seconds
Time After: 0.04086 seconds
Time Taken: 0.00117 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.03535 seconds
Time After: 0.04110 seconds
Time Taken: 0.00575 seconds
Memory After: 2,261.719 KB
Time Before: 0.06468 seconds
Time After: 0.06482 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.07656 seconds
Time After: 0.07778 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.08440 seconds
Time After: 0.08456 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.08720 seconds
Time After: 0.08865 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=83284' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.10698 seconds
Time After: 0.10727 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
