Time Before: 0.00196 seconds
Time After: 0.00241 seconds
Time Before: 0.00248 seconds
Time After: 0.00293 seconds
Time Before: 0.00311 seconds
Time After: 0.00321 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00388 seconds
Time After: 0.00615 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00326 seconds
Time After: 0.01092 seconds
Time Taken: 0.00766 seconds
Time Before: 0.01313 seconds
Time After: 0.01339 seconds
Time Before: 0.01603 seconds
Time After: 0.01746 seconds
Time Before: 0.01239 seconds
Time After: 0.01773 seconds
Time Taken: 0.00534 seconds
Time Before: 0.02500 seconds
Time After: 0.02514 seconds
Time Before: 0.02737 seconds
Time After: 0.02866 seconds
Time Before: 0.03160 seconds
Time After: 0.03176 seconds
Time Before: 0.03381 seconds
Time After: 0.03534 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=83316', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04776 seconds
Time After: 0.04808 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
