Time Before: 0.00167 seconds
Time After: 0.00224 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00235 seconds
Time After: 0.00315 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00344 seconds
Time After: 0.00362 seconds
Time Before: 0.00452 seconds
Time After: 0.00763 seconds
Time Taken: 0.00310 seconds
Time Before: 0.00370 seconds
Time After: 0.01112 seconds
Time Taken: 0.00742 seconds
Time Before: 0.01320 seconds
Time After: 0.01358 seconds
Time Before: 0.01606 seconds
Time After: 0.01741 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01260 seconds
Time After: 0.01767 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02370 seconds
Time After: 0.02385 seconds
Time Before: 0.02570 seconds
Time After: 0.02698 seconds
End call of global.php: 0.028653860092163
Time Before: 0.02987 seconds
Time After: 0.03013 seconds
Time Before: 0.03263 seconds
Time After: 0.03419 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1783235118, location = '/forums/private.php?do=newpm&explain=1&u=83328'
Time Before: 0.04767 seconds
Time After: 0.04798 seconds
Memory Before: 4,911.945 KB
Memory After: 4,912.172 KB
Page generated in 0.046724796295166 seconds with 9 queries, spending 0.0093719959259033 doing MySQL queries and 0.037352800369263 doing PHP things.
