Time Before: 0.00146 seconds
Time After: 0.00193 seconds
Time Before: 0.00200 seconds
Time After: 0.00236 seconds
Time Before: 0.00257 seconds
Time After: 0.00269 seconds
Time Before: 0.00358 seconds
Time After: 0.00647 seconds
Time Taken: 0.00289 seconds
Time Before: 0.00274 seconds
Time After: 0.01153 seconds
Time Taken: 0.00879 seconds
Time Before: 0.01348 seconds
Time After: 0.01392 seconds
Time Before: 0.01721 seconds
Time After: 0.01838 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01287 seconds
Time After: 0.01857 seconds
Time Taken: 0.00570 seconds
Time Before: 0.02527 seconds
Time After: 0.02542 seconds
Time Before: 0.02759 seconds
Time After: 0.02889 seconds
End call of global.php: 0.030624866485596
Time Before: 0.03187 seconds
Time After: 0.03199 seconds
Time Before: 0.03411 seconds
Time After: 0.03552 seconds
SET lastactivity = 1776475179, location = '/forums/private.php?do=newpm&explain=1&u=8333'
Time Before: 0.04869 seconds
Time After: 0.04895 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.500 KB
Page generated in 0.047762870788574 seconds with 9 queries, spending 0.0082135200500488 doing MySQL queries and 0.039549350738525 doing PHP things.
