Time Before: 0.00432 seconds
Time After: 0.00634 seconds
Time Taken: 0.00202 seconds
Time Before: 0.00641 seconds
Time After: 0.00679 seconds
Time Before: 0.00701 seconds
Time After: 0.00713 seconds
Time Before: 0.00787 seconds
Time After: 0.00990 seconds
Time Before: 0.00718 seconds
Time After: 0.01330 seconds
Time Taken: 0.00613 seconds
Time Before: 0.01758 seconds
Time After: 0.01799 seconds
Time Before: 0.02110 seconds
Time After: 0.02228 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01696 seconds
Time After: 0.02246 seconds
Time Taken: 0.00550 seconds
Memory After: 2,261.836 KB
Time Before: 0.03206 seconds
Time After: 0.03219 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.04107 seconds
Time After: 0.04303 seconds
Time Taken: 0.00196 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.044738054275513
Time Before: 0.04839 seconds
Time After: 0.04854 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.05074 seconds
Time After: 0.05225 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788944787, location = '/forums/private.php?do=newpm&explain=1&u=8335', badlocation = 1
Time Before: 0.06600 seconds
Time After: 0.06633 seconds
Memory Before: 4,287.867 KB
Memory After: 4,288.078 KB
Page generated in 0.065102100372314 seconds with 9 queries, spending 0.0081925392150879 doing MySQL queries and 0.056909561157227 doing PHP things.
