Time Before: 0.01115 seconds
Time After: 0.01560 seconds
Time Taken: 0.00444 seconds
Time Before: 0.01569 seconds
Time After: 0.01616 seconds
Time Before: 0.01641 seconds
Time After: 0.01657 seconds
Time Before: 0.01745 seconds
Time After: 0.02037 seconds
Time Taken: 0.00292 seconds
Time Before: 0.01665 seconds
Time After: 0.02466 seconds
Time Taken: 0.00801 seconds
Time Before: 0.02809 seconds
Time After: 0.02853 seconds
Time Before: 0.03158 seconds
Time After: 0.03277 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.02727 seconds
Time After: 0.03301 seconds
Time Taken: 0.00574 seconds
Memory After: 2,261.719 KB
Time Before: 0.05369 seconds
Time After: 0.05387 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.06394 seconds
Time After: 0.06541 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.067255020141602
Time Before: 0.06985 seconds
Time After: 0.06999 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.07283 seconds
Time After: 0.07430 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=83366', badlocation = 1
Time Before: 0.09416 seconds
Time After: 0.09441 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.09306001663208 seconds with 9 queries, spending 0.0087018013000488 doing MySQL queries and 0.084358215332031 doing PHP things.
