Time Before: 0.01213 seconds
Time After: 0.02377 seconds
Time Taken: 0.01165 seconds
Time Before: 0.02387 seconds
Time After: 0.02831 seconds
Time Taken: 0.00444 seconds
Time Before: 0.02980 seconds
Time After: 0.03131 seconds
Time Taken: 0.00151 seconds
Time Before: 0.03335 seconds
Time After: 0.03894 seconds
Time Taken: 0.00559 seconds
Time Before: 0.03138 seconds
Time After: 0.04384 seconds
Time Taken: 0.01246 seconds
Time Before: 0.05732 seconds
Time After: 0.05771 seconds
Time Before: 0.06072 seconds
Time After: 0.06193 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.05643 seconds
Time After: 0.06219 seconds
Time Taken: 0.00576 seconds
Memory After: 2,261.719 KB
Time Before: 0.09033 seconds
Time After: 0.09047 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10941 seconds
Time After: 0.11063 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.11292004585266
Time Before: 0.12109 seconds
Time After: 0.12148 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12410 seconds
Time After: 0.12565 seconds
Time Taken: 0.00155 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=83434'
Time Before: 0.14554 seconds
Time After: 0.14620 seconds
Time Taken: 0.00066 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
Page generated in 0.14435410499573 seconds with 9 queries, spending 0.017100811004639 doing MySQL queries and 0.12725329399109 doing PHP things.
