Time Before: 0.01130 seconds
Time After: 0.01439 seconds
Time Taken: 0.00309 seconds
Time Before: 0.01446 seconds
Time After: 0.01479 seconds
Time Before: 0.01498 seconds
Time After: 0.01509 seconds
Time Before: 0.01582 seconds
Time After: 0.01812 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01514 seconds
Time After: 0.02238 seconds
Time Taken: 0.00724 seconds
Time Before: 0.02941 seconds
Time After: 0.02981 seconds
Time Before: 0.03259 seconds
Time After: 0.03389 seconds
Time Before: 0.02860 seconds
Time After: 0.03413 seconds
Time Taken: 0.00553 seconds
Time Before: 0.05407 seconds
Time After: 0.05420 seconds
Time Before: 0.06151 seconds
Time After: 0.06281 seconds
End call of global.php: 0.065471887588501
Time Before: 0.07032 seconds
Time After: 0.07048 seconds
Time Before: 0.07287 seconds
Time After: 0.07477 seconds
Time Taken: 0.00190 seconds
SET lastactivity = 1785404266, location = '/forums/private.php?do=newpm&explain=1&u=83489', badlocation = 1
Time Before: 0.09274 seconds
Time After: 0.09300 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.091522932052612 seconds with 9 queries, spending 0.0081937313079834 doing MySQL queries and 0.083329200744629 doing PHP things.
