Time Before: 0.03400 seconds
Time After: 0.04131 seconds
Time Taken: 0.00731 seconds
Time Before: 0.04139 seconds
Time After: 0.04177 seconds
Time Before: 0.04201 seconds
Time After: 0.04219 seconds
Time Before: 0.04299 seconds
Time After: 0.04534 seconds
Time Taken: 0.00235 seconds
Time Before: 0.04227 seconds
Time After: 0.04958 seconds
Time Before: 0.05873 seconds
Time After: 0.05914 seconds
Time Before: 0.06059 seconds
Time After: 0.06175 seconds
Time Taken: 0.00117 seconds
Time Before: 0.05800 seconds
Time After: 0.06196 seconds
Time Taken: 0.00396 seconds
Time Before: 0.11514 seconds
Time After: 0.11538 seconds
Time Before: 0.23848 seconds
Time After: 0.23970 seconds
End call of global.php: 0.24259495735168
Time Before: 0.25366 seconds
Time After: 0.25383 seconds
Time Before: 0.25613 seconds
Time After: 0.25754 seconds
SET lastactivity = 1776755908, location = '/forums/private.php?do=newpm&explain=1&u=83512'
Time Before: 0.27250 seconds
Time After: 0.27274 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.27154302597046 seconds with 9 queries, spending 0.0077724456787109 doing MySQL queries and 0.26377058029175 doing PHP things.
