Time Before: 0.01952 seconds
Time After: 0.02801 seconds
Time Taken: 0.00849 seconds
Time Before: 0.02811 seconds
Time After: 0.02860 seconds
Time Before: 0.02895 seconds
Time After: 0.02910 seconds
Time Before: 0.02998 seconds
Time After: 0.03213 seconds
Time Taken: 0.00215 seconds
Time Before: 0.02920 seconds
Time After: 0.03653 seconds
Time Taken: 0.00733 seconds
Time Before: 0.04021 seconds
Time After: 0.04071 seconds
Time Before: 0.04395 seconds
Time After: 0.04515 seconds
Time Before: 0.03953 seconds
Time After: 0.04537 seconds
Time Taken: 0.00585 seconds
Time Before: 0.08575 seconds
Time After: 0.08590 seconds
Time Before: 0.11015 seconds
Time After: 0.11137 seconds
End call of global.php: 0.11339497566223
Time Before: 0.12422 seconds
Time After: 0.12437 seconds
Time Before: 0.12688 seconds
Time After: 0.12833 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=83527', badlocation = 1
Time Before: 0.14602 seconds
Time After: 0.14631 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
Page generated in 0.14495587348938 seconds with 9 queries, spending 0.0077404975891113 doing MySQL queries and 0.13721537590027 doing PHP things.
