Time Before: 0.00310 seconds
Time After: 0.00513 seconds
Time Taken: 0.00203 seconds
Memory Before: 533.906 KB
Memory After: 559.023 KB
Time Before: 0.00522 seconds
Time After: 0.00575 seconds
Time Taken: 0.00053 seconds
Memory Before: 558.961 KB
Memory After: 559.969 KB
Time Before: 0.00599 seconds
Time After: 0.00610 seconds
Memory Before: 560.523 KB
Memory After: 561.047 KB
Time Before: 0.00689 seconds
Time After: 0.01061 seconds
Time Taken: 0.00372 seconds
Memory Before: 563.648 KB
Memory After: 564.570 KB
Time Before: 0.00617 seconds
Time After: 0.01514 seconds
Time Taken: 0.00897 seconds
Memory Before: 560.297 KB
Memory After: 1,641.297 KB
Memory Used: 1,081.000 KB
Time Before: 0.01835 seconds
Time After: 0.01873 seconds
Memory Before: 2,136.141 KB
Memory After: 2,136.758 KB
Time Before: 0.02187 seconds
Time After: 0.02308 seconds
Memory Before: 2,148.320 KB
Memory After: 2,148.180 KB
Time Before: 0.01768 seconds
Time After: 0.02334 seconds
Time Taken: 0.00565 seconds
Memory Before: 2,128.320 KB
Memory After: 2,261.203 KB
Time Before: 0.03181 seconds
Time After: 0.03193 seconds
Memory Before: 2,814.781 KB
Memory After: 2,815.297 KB
Time Before: 0.03375 seconds
Time After: 0.03503 seconds
Memory Before: 2,903.117 KB
Memory After: 2,903.711 KB
Time Before: 0.03782 seconds
Time After: 0.03795 seconds
Memory Before: 3,539.836 KB
Memory After: 3,540.266 KB
Time Before: 0.03993 seconds
Time After: 0.04147 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.367 KB
Memory After: 3,823.055 KB
UPDATE session SET lastactivity = 1789146927, location = '/forums/private.php?do=newpm&explain=1&u=83592' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05964 seconds
Time After: 0.05995 seconds
Memory Before: 4,295.203 KB
Memory After: 4,295.430 KB
