Time Before: 0.00217 seconds
Time After: 0.00283 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00291 seconds
Time After: 0.00337 seconds
Time Before: 0.00363 seconds
Time After: 0.00375 seconds
Time Before: 0.00461 seconds
Time After: 0.00692 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00383 seconds
Time After: 0.01039 seconds
Time Taken: 0.00655 seconds
Time Before: 0.01221 seconds
Time After: 0.01257 seconds
Time Before: 0.01510 seconds
Time After: 0.01639 seconds
Time Before: 0.01163 seconds
Time After: 0.01666 seconds
Time Taken: 0.00503 seconds
Time Before: 0.02296 seconds
Time After: 0.02321 seconds
Time Before: 0.02538 seconds
Time After: 0.02665 seconds
End call of global.php: 0.028653860092163
Time Before: 0.02983 seconds
Time After: 0.03048 seconds
Time Taken: 0.00064 seconds
Time Before: 0.03307 seconds
Time After: 0.03452 seconds
SET lastactivity = 1776799811, location = '/forums/private.php?do=newpm&explain=1&u=83605', badlocation = 1
Time Before: 0.05306 seconds
Time After: 0.05340 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.051632881164551 seconds with 9 queries, spending 0.0085017681121826 doing MySQL queries and 0.043131113052368 doing PHP things.
