Time Before: 0.00203 seconds
Time After: 0.00262 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00273 seconds
Time After: 0.00324 seconds
Time Before: 0.00355 seconds
Time After: 0.00369 seconds
Time Before: 0.00461 seconds
Time After: 0.00679 seconds
Time Taken: 0.00218 seconds
Time Before: 0.00376 seconds
Time After: 0.01241 seconds
Time Taken: 0.00865 seconds
Time Before: 0.01543 seconds
Time After: 0.01591 seconds
Time Before: 0.01894 seconds
Time After: 0.02014 seconds
Time Before: 0.01449 seconds
Time After: 0.02046 seconds
Time Taken: 0.00597 seconds
Time Before: 0.02568 seconds
Time After: 0.02583 seconds
Time Before: 0.02791 seconds
Time After: 0.02926 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.030889987945557
Time Before: 0.03206 seconds
Time After: 0.03221 seconds
Time Before: 0.03420 seconds
Time After: 0.03565 seconds
SET lastactivity = 1783196295, location = '/forums/private.php?do=newpm&explain=1&u=83625'
Time Before: 0.04830 seconds
Time After: 0.04858 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.04735803604126 seconds with 9 queries, spending 0.0078983306884766 doing MySQL queries and 0.039459705352783 doing PHP things.
