Time Before: 0.00534 seconds
Time After: 0.00682 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00689 seconds
Time After: 0.00737 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00759 seconds
Time After: 0.00771 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00857 seconds
Time After: 0.01093 seconds
Time Taken: 0.00236 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00776 seconds
Time After: 0.01533 seconds
Time Taken: 0.00757 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.766 KB
Time Before: 0.01892 seconds
Time After: 0.01917 seconds
Memory Before: 2,759.469 KB
Memory After: 2,760.086 KB
Time Before: 0.02177 seconds
Time After: 0.02299 seconds
Memory Before: 2,771.641 KB
Memory After: 2,771.500 KB
Time Before: 0.01819 seconds
Time After: 0.02323 seconds
Time Taken: 0.00503 seconds
Memory Before: 2,751.609 KB
Memory After: 2,884.531 KB
Time Before: 0.03324 seconds
Time After: 0.03336 seconds
Memory Before: 3,437.641 KB
Memory After: 3,438.156 KB
Time Before: 0.03937 seconds
Time After: 0.04067 seconds
Memory Before: 3,525.438 KB
Memory After: 3,526.031 KB
End call of global.php: 0.042898893356323
Time Before: 0.04596 seconds
Time After: 0.04614 seconds
Memory Before: 4,163.305 KB
Memory After: 4,163.734 KB
Time Before: 0.04851 seconds
Time After: 0.04999 seconds
Memory Before: 4,444.867 KB
Memory After: 4,446.555 KB
SET lastactivity = 1788957271, location = '/forums/private.php?do=newpm&explain=1&u=83631'
Time Before: 0.06855 seconds
Time After: 0.06961 seconds
Time Taken: 0.00106 seconds
Memory Before: 4,918.703 KB
Memory After: 4,918.930 KB
Page generated in 0.067280054092407 seconds with 9 queries, spending 0.0085699558258057 doing MySQL queries and 0.058710098266602 doing PHP things.
