Time Before: 0.00178 seconds
Time After: 0.00249 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00256 seconds
Time After: 0.00319 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00346 seconds
Time After: 0.00360 seconds
Time Before: 0.00427 seconds
Time After: 0.00693 seconds
Time Taken: 0.00266 seconds
Time Before: 0.00365 seconds
Time After: 0.01034 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01207 seconds
Time After: 0.01250 seconds
Time Before: 0.01487 seconds
Time After: 0.01611 seconds
Time Before: 0.01150 seconds
Time After: 0.01628 seconds
Time Taken: 0.00479 seconds
Time Before: 0.02140 seconds
Time After: 0.02157 seconds
Time Before: 0.02362 seconds
Time After: 0.02487 seconds
End call of global.php: 0.026575088500977
Time Before: 0.02788 seconds
Time After: 0.02803 seconds
Time Before: 0.03000 seconds
Time After: 0.03142 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=83686', badlocation = 1
Time Before: 0.04390 seconds
Time After: 0.04420 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.042999029159546 seconds with 9 queries, spending 0.0083906650543213 doing MySQL queries and 0.034608364105225 doing PHP things.
