Time Before: 0.00296 seconds
Time After: 0.00360 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00367 seconds
Time After: 0.00400 seconds
Time Before: 0.00423 seconds
Time After: 0.00433 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00498 seconds
Time After: 0.00760 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00438 seconds
Time After: 0.01130 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01329 seconds
Time After: 0.01368 seconds
Time Before: 0.01610 seconds
Time After: 0.01736 seconds
Time Before: 0.01267 seconds
Time After: 0.01754 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02318 seconds
Time After: 0.02331 seconds
Time Before: 0.02547 seconds
Time After: 0.02677 seconds
End call of global.php: 0.029515027999878
Time Before: 0.03107 seconds
Time After: 0.03126 seconds
Time Before: 0.03374 seconds
Time After: 0.03524 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=83844'
WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.05145 seconds
Time After: 0.05174 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.050405025482178 seconds with 9 queries, spending 0.0081131458282471 doing MySQL queries and 0.042291879653931 doing PHP things.
