Time Before: 0.02083 seconds
Time After: 0.02665 seconds
Time Taken: 0.00582 seconds
Time Before: 0.02673 seconds
Time After: 0.02720 seconds
Time Before: 0.02746 seconds
Time After: 0.02759 seconds
Time Before: 0.02838 seconds
Time After: 0.03177 seconds
Time Taken: 0.00339 seconds
Time Before: 0.02766 seconds
Time After: 0.03572 seconds
Time Taken: 0.00806 seconds
Time Before: 0.04300 seconds
Time After: 0.04322 seconds
Time Before: 0.04563 seconds
Time After: 0.04685 seconds
Time Before: 0.04228 seconds
Time After: 0.04704 seconds
Time Taken: 0.00476 seconds
Time Before: 0.07660 seconds
Time After: 0.07677 seconds
Time Before: 0.12958 seconds
Time After: 0.13085 seconds
End call of global.php: 0.13289904594421
Time Before: 0.14030 seconds
Time After: 0.14047 seconds
Time Before: 0.14301 seconds
Time After: 0.14447 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=8388'
Time Before: 0.16065 seconds
Time After: 0.16092 seconds
Memory Before: 4,287.719 KB
Memory After: 4,287.969 KB
Memory Used: 0.250 KB
Page generated in 0.15925002098083 seconds with 9 queries, spending 0.0087900161743164 doing MySQL queries and 0.15046000480652 doing PHP things.
