Time Before: 0.00203 seconds
Time After: 0.00327 seconds
Time Before: 0.00337 seconds
Time After: 0.00394 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00434 seconds
Time After: 0.00449 seconds
Time Before: 0.00556 seconds
Time After: 0.00917 seconds
Time Taken: 0.00361 seconds
Time Before: 0.00457 seconds
Time After: 0.01400 seconds
Time Taken: 0.00943 seconds
Time Before: 0.01578 seconds
Time After: 0.01626 seconds
Time Before: 0.01868 seconds
Time After: 0.01992 seconds
Time Before: 0.01518 seconds
Time After: 0.02010 seconds
Time Taken: 0.00492 seconds
Time Before: 0.02509 seconds
Time After: 0.02526 seconds
Time Before: 0.02772 seconds
Time After: 0.02900 seconds
Time Before: 0.03277 seconds
Time After: 0.03294 seconds
Time Before: 0.03492 seconds
Time After: 0.03641 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=83967', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04867 seconds
Time After: 0.04938 seconds
Time Taken: 0.00071 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
