Time Before: 0.01551 seconds
Time After: 0.01910 seconds
Time Taken: 0.00359 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.01920 seconds
Time After: 0.01967 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.01989 seconds
Time After: 0.02001 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.02087 seconds
Time After: 0.02378 seconds
Time Taken: 0.00291 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.02008 seconds
Time After: 0.02826 seconds
Time Taken: 0.00818 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.03844 seconds
Time After: 0.03878 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.04114 seconds
Time After: 0.04239 seconds
Memory Before: 2,908.320 KB
Memory After: 2,908.180 KB
Time Before: 0.03774 seconds
Time After: 0.04265 seconds
Time Taken: 0.00490 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.250 KB
Memory Used: 132.648 KB
Time Before: 0.07228 seconds
Time After: 0.07246 seconds
Memory Before: 3,655.805 KB
Memory After: 3,656.320 KB
Time Before: 0.12359 seconds
Time After: 0.12486 seconds
Memory Before: 4,133.352 KB
Memory After: 4,133.945 KB
Time Before: 0.15153 seconds
Time After: 0.15205 seconds
Memory Before: 5,197.547 KB
Memory After: 5,325.891 KB
Time Before: 0.15775 seconds
Time After: 0.15925 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.227 KB
Memory After: 5,610.828 KB
UPDATE session SET lastactivity = 1768720615, location = '/forums/private.php?do=newpm&explain=1&u=84029' WHERE sessionhash = '493329e92668bdfe23f60c8f4163b3e0'
Time Before: 0.18300 seconds
Time After: 0.18674 seconds
Time Taken: 0.00374 seconds
Memory Before: 5,998.531 KB
Memory After: 5,998.750 KB
