Time Before: 0.00431 seconds
Time After: 0.00523 seconds
Time Taken: 0.00091 seconds
Time Before: 0.00534 seconds
Time After: 0.00583 seconds
Time Before: 0.00605 seconds
Time After: 0.00617 seconds
Time Before: 0.00682 seconds
Time After: 0.00918 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00622 seconds
Time After: 0.01265 seconds
Time Taken: 0.00642 seconds
Time Before: 0.01501 seconds
Time After: 0.01538 seconds
Time Before: 0.01776 seconds
Time After: 0.01900 seconds
Time Before: 0.01441 seconds
Time After: 0.01923 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02785 seconds
Time After: 0.02801 seconds
Time Before: 0.03266 seconds
Time After: 0.03389 seconds
End call of global.php: 0.035621881484985
Time Before: 0.03758 seconds
Time After: 0.03777 seconds
Time Before: 0.03976 seconds
Time After: 0.04119 seconds
SET lastactivity = 1776567553, location = '/forums/private.php?do=newpm&explain=1&u=84065'
Time Before: 0.05675 seconds
Time After: 0.05702 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
Page generated in 0.055773973464966 seconds with 9 queries, spending 0.0078630447387695 doing MySQL queries and 0.047910928726196 doing PHP things.
